+ Native 64-bit version of Uninstall Tool
+ 'Install and Trace' item in Windows 7 taskbar popup
* fixed Install Tracker choosing of main item
* fixed reloading of program list after uninstallation
* Improved the dialog informing about running processes
* improved icon detection
* ability to enter space character in the search filter
* fixed saving/restoring of main window position
Download now!
Comments:
Uninstall Tool x86 is full functional in 64-bit Windows though it has some limitations and it's become hard to maintain x64 support. Thus we decided to switch to native 64-bit version of Uninstall Tool for 3.1 release. One setup will include both 64-bit and 32-bit modules and will install the required version depending on the current Windows. 64-bit version will display and work correctly with both native 64-bit programs as well as x86 (WoW64)
Information for translators:
New strings to translate:
- UninstallWizard/statusScanningTraced
- UninstallWizard/statusForceRemoval
- Messages/msgForceRemovalDescriptionTraced
- Messages/msgRunningInWow64
- Messages/msgRunningInWow64Title
- Messages/msgCannotStartHelper
